SWX16,17
Linked properties of saved bodies of weldment part is not correct in drawing notes.
For example, I gave Part Number property for each cut list item and saved bodies with option "copy cut list property to cusom property" checked.
When I made drawing of saved body I see in title block or linked notes the Part Number property of parent part, not saved body. This situation is with all "Linked to Parent" properties.
Problem is solved in SWX18!
Now SW doesn`t override cut-list properties by custom properties of the same name in case of saving derived bodies.
