2 Replies Latest reply on Dec 23, 2015 12:23 PM by Carlos Carneiro
    Macro to change Author, Comments, keywords, etc in all parts/assembly in one folder
    Carlos Carneiro
      Greetings,
      I'd like to know if there's a way to make a Macro that sets or ovewrites the Author, keywords, comments and title in the Summary information of all parts and assemblies that are located in one folder, something like "open, change values, save, close" automatically. if there was a popup window wita field to define the desire values great, if not, changing it in the code would also be just fine.
      I found some code from Deepak Gupta  here but the code doesnt overwite the values.
      Thank you all for your attention.
      Best regards,
      Carlos
        • Re: Macro to change Author, Comments, keywords, etc in all parts/assembly in one folder
          Deepak Gupta
          These will set the two field and you can edit the codes for other fields.
          Dim swApp               As SldWorks.SldWorks
          Dim swModel             As SldWorks.ModelDoc2
          Set swModel = swApp.ActiveDoc
          swModel.SummaryInfo(swSumInfoAuthor) = "Author name Here"
          swModel.SummaryInfo(swSumInfoComment) = "Comments Here"
              Carlos Carneiro
              Greatings,
              Thank you for your help, I combined code from some of your macros and got this
              [code]
              Option Explicit
              Private Const BIF_RETURNONLYFSDIRS As Long = &H1
              Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
              Private Const BIF_RETURNFSANCESTORS As Long = &H8
              Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
              Private Const BIF_BROWSEFORPRINTER As Long = &H2000
              Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
              Private Const MAX_PATH As Long = 260
              Dim swModelDocExt      As SldWorks.ModelDocExtension
              Dim Path                As String
              Dim swFilename          As String
              Dim nErrors            As Long
              Dim nWarnings          As Long
              Dim Response            As String
              Dim DocName            As String
              Dim bret                As Boolean
              Dim swDocTypeLong      As Long
              Dim vConfs              As Variant
              Dim vPropNames          As Variant
              Dim i                  As Integer
              Dim j                  As Integer
              Dim fso                As New Scripting.FileSystemObject
              Dim MYext              As String
              Dim swCustPropMgr      As SldWorks.CustomPropertyManager
              Dim tDate              As String
                Dim value              As String
                  Dim svalue              As String
                  Dim kvalue              As String
                  Dim tvalue              As String
              Function BrowseFolder(Optional Caption As String, _
                  Optional InitialFolder As String) As String
              Dim SH As Shell32.Shell
              Dim F As Shell32.folder
              Set SH = New Shell32.Shell
              Set F = SH.BrowseForFolder(0&, Caption, BIF_RETURNONLYFSDIRS, InitialFolder)
              If Not F Is Nothing Then
                  BrowseFolder = F.Items.Item.Path
              End Function
                  Path = BrowseFolder()
                  If Path = "" Then
                  MsgBox "Please select the path and try again"
                  End
                  Else
                  Path = Path & "\"
                  BatchFolder Path, ".SLDPRT", ".SLDASM", True
                  MsgBox "DONE"
              Sub BatchFolder(folder As String, ext As String, ext2 As String, silent As Boolean)
                  If Right(folder, 1) <> "\" Then folder = folder & "\"
                  ChDir (folder)
                  Response = Dir(folder)
                  Do Until Response = ""
                      swFilename = folder & Response
                      Debug.Print swFilename
                      MYext = Right(UCase$(Response), 7)
                      If MYext = ext Or MYext = ext2 Then 'this is a file type we want, process it
                          swDocTypeLong = Switch(MYext = ".SLDPRT", swDocPART, MYext = ".SLDDRW", swDocDRAWING, MYext = ".SLDASM", swDocASSEMBLY, True, -1)
                          Set swModel = swApp.OpenDoc6(swFilename, swDocTypeLong, swOpenDocOptions_Silent, "", nErrors, nWarnings)
                          Set swModelDocExt = swModel.Extension
                        value = swModel.SummaryInfo(swSumInfoAuthor)
              If Not value = "" Then
              swModel.SummaryInfo(swSumInfoAuthor) = "AUTHOR"
              Else
              'Get and set the Comment KeyWord in the File Summary Info
              svalue = swModel.SummaryInfo(swSumInfoComment)
              If Not svalue = "" Then
              swModel.SummaryInfo(swSumInfoComment) = "COMMENT"
              Else
              kvalue = swModel.SummaryInfo(swSumInfoKeywords)
              swModel.SummaryInfo(swSumInfoKeywords) = "KEYWORDS"
              Else
              tvalue = swModel.SummaryInfo(swSumInfoTitle)
              swModel.SummaryInfo(swSumInfoTitle) = "TITLE"
              Else
                          swModel.ShowNamedView2 "*Isometric", -1
                          swModel.ViewZoomtofit2
                          swModel.ForceRebuild3 False
                          swModel.Save2 silent
                          swApp.CloseAllDocuments (True)
                      Response = Dir
                  Loop
                  Dim myFolder As folder
                  Dim mySub As folder
                  Set myFolder = fso.GetFolder(folder)
                  For Each mySub In myFolder.SubFolders
                      BatchFolder mySub.Path, ext, ext2, silent
              '      Debug.Print mySub.Path
                  Next
              Sub ClearCustPrps(conf As String)
                  Set swCustPropMgr = swModelDocExt.CustomPropertyManager(conf)
                  If Not swCustPropMgr Is Nothing Then
                      swCustPropMgr.GetAll vPropNames, Empty, Empty
                      If Not IsEmpty(vPropNames) Then
                          For j = 0 To UBound(vPropNames)
                              Debug.Print " ClearCustPrps: " & vPropNames(j)
                              swCustPropMgr.Delete vPropNames(j)
                          Next
              [/code]
              I got it to work like i Intended to, select a folder, it opens, changes values, saves and closes all the parts.
              Now I wanted to get it to prompt a window on run where I could input the values so I didn't need to edit the code everytime.
              Can you tell me where I can find an example on how to do it?
              Best regards,
              Carlos
