When I dimension an arc length in a drawing the dimension turns into a degree (and not the correct one). I have tried selecting the end points then the arc and selecting the arc then the end points and I get the same effect. On my sketches I get the expected dimension of an arc length. This doesn't seem to be a document property problem. If it is I don't know which one.
Anybody got a solution?
Peter,
I get this a lot. Sometimes it does it sometimes not. When I want a length and it is giving me an angle what I do is use the sketch point tool and put a sketch point on each end of the arc, then use them to dimension, this will usually then give you the length as expected.
I know its a workaround but....
