I have a custom cut extrude in my library. Its a panel cut out for a DB-25 connector. I have a panel in which this connector will be upside down, so I need to rotate this extrude 180° as I drag the library extrude unto my panel. I see no option for rotating it during this process of adding the library extrude nor after.
ha ha ha... wow... this shows JUST how much of a noob I still am.
I just have to edit the sketch hit the move entities tab and select rotate and do the necessary steps of selecting all the sketch entities to be rotated and then the point around which everything will rotate. Some vertical and horizontal relations may need to be deleted then re-added afterward if certain entities don't rotate with the whole selection.
Gonna leave this up here anyway in case someone has the same brain fart that I just had.
Cheers!!!
