I remember that while at a previous employer we were able to select a material gauge when making a sheet metal part and have the company's material description and material part number added to the custom properties. I have spent the last few days searching the forum and different blogs in an attempt to learn how to do this for my current company but have not found anything that could even get me started.
Is my memory incorrect? Or can someone point me in the correct direction for a tutorial for working with Gauge tables. Most information I find deals more with bend tables.
We are in 2015 and will soon be going to 16 ( if the UI doesn't dissuade us.)
Thank you
Jim
Edit:
This one might help K-factor Bend table problems
or might just confuse you more, sorry.
Was it more then one table ? different table for different material ?
Do you first want to select e.g. The AISI gauge table, and then select the gauge from it?
What exactly do you want to end up with in the description, can you please give an example.
