1 Reply Latest reply on Dec 22, 2015 7:00 PM by Yong Ning
    How get feature name in create circle.
    Yong Ning
      follow code.
               SwSktSeg.Select2 True, 0 →  can be select
               Set SwFeat = SwSelMgr.GetSelectedObject5(1) → don't set SwFeat
      Private Sub ll()
         Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
            Set SwApp = Application.SldWorks
            Set SwModel = SwApp.ActiveDoc
         Dim SwSelMgr As SelectionMgr
            Set SwSelMgr = SwModel.SelectionManager
         Dim SwSktSeg  As SketchSegment, SwFeat As Feature, SwSketch As Sketch
            With SwModel
               'tmp = .Extension.SelectByID2("上视基准面", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
               tmp = .Extension.SelectByID2("上视", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
               Set SwSktSeg = .CreateCircleByRadius2(0, 0, 0, 24)
               SwSktSeg.Select True
               SwSktSeg.GetSketch
               .InsertSketch2 True
               Set SwSketch = SwSktSeg.GetSketch
               Stop
            End With
        • Re: How get feature name in create circle.
          Yong Ning
          Traverse select Feature of Sketch name, change Feature name.
          Private Sub ll3()
             Dim Xls As Excel.Application, Rng As Range
                Set Xls = GetObject(, "Excel.Application")
                Set Rng = Xls.Selection
                With SwModel
                   For ii = 1 To Rng.Rows.Count
                       tmp = .Extension.SelectByID2("Sketch" & ii, "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
                       Debug.Print SwFeat.Name
                       SwFeat.Name = Rng(ii, 1)
                   Next ii
                End With
          How to get the feature name of Cut-Extrude? | SOLIDWORKS Forums
          https://forum.solidworks.com/message/466157#466157
          Private Sub ll()
            Dim SwSelMgr As SelectionMgr, Tmp
            Dim SwFeat As Feature
            Dim SwAnn As Annotation, S As Sketch
               With SwModel
                  Tmp = .Extension.SelectByID2("上视", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
                  .CreateCircleByRadius2 0, 0, 0, 38.5 / 2 / 1000
                  .ClearSelection2 True
                  Set SwFeat = .GetActiveSketch
                  'SwFeat.Select True
                  SwFeat.Name = "f1"
                  SwFeat.Select True
                  Stop
                  Set SwFeat = .FeatureManager.FeatureCut(True, False, True, swEndCondThroughAll, _
                    swEndCondBlind, 0, 0, False, False, False, False, 0, 0, False, False, False, False, 0, 1, 1)
                  Stop
                  SwFeat.Name = "fffffff"
                  SwFeat.Select True
                  SwModel.EditSuppress
               End With
