Have to do freefall of a ball, witch is conected with a rope. rope is 15meter length and one of rope end's is fixed... have to see how a ball is hanging after fall, and how affect the rope.. any sugestions? Thanks
That is very complex, because the material/structure shows very anisotropic behaviour.
If loading is (mostly) pure tensile, you can do it with some assumptions.
What about this situation: ( https://www.google.lt/search?q=rope+jumping&rlz=1C1ASUC_enLT637LT637&espv=2&biw=2560&bih=1281&source=lnms&tbm=isch&sa=X&… ) posible to calculate forces and stress at the end of the rope (on carabiners) ?
If Yes, give me a hint
I would day that the material that you use for the rope is hyperelastic. So you should use non-linear static or maybe even non-linear dynamics.
The assumption that you will have to make is if the cross-section is homogenous, or that you use a braided material. I guess the used material is braided and not homogenous.
If it is braided the simulation is very complex and time consuming, due to complex non-linear contacts and large deformations occuring.
So if you are not a very experienced user of simulation, maybe this will become to compex for you.
Rope Animation in SolidWorks - YouTube
