First of all sorry for my English.
I have a question about if SolidWorks can show me the points, lines, etc. That aren't defined. I want all the sketches "fully defined" but sometimes in a rare sketch I have points that if I don't have so much attention I can't see. I'm looking for some similiar tool like in CATIA "Sketch Solving Status", in SolidWorks we have "show/hide relations" but I'm looking for some tool to see the entities that have no relation and make the sketch under defined.
Thanks in advance.
Mr. Palma,
I suggest using the repair sketch as it will give you a magnifying glass on some problems. It will get rid of lines on top of lines as well as show you open gaps and short lines. These are the rookie mistakes you will get over as your SolidWorks' Skills increase in efficiency.
If you use the repair sketch and you're still under defined, then use the "Fully Defined Sketch" feature with Ordinate dimensions. 90% of my models use baseline dimensions so the ordinate will clash to be able to see easier. If my model has ordinate dimensions then I will use a different reference to be able to see easier. Basically you zoom in to the area where the ordinate dimension is attached, delete the ordinate dimension, and put in your intent. See last 3 pictures.
