Hello all
I create a spring with sweep command in two way according to attach files.
is there another way to create it with sweep command .
thanks a lot
Here is a third method
Leszek
Hello Leszek
thanks for reply
i can't understand how you create (Szkic 3D1 )
i think the spline must be intersection of (Powierzchnia-Wyciągnięcie po ścieżce2) and (Powierzchnia-Wyciągnięcie po ścieżce1).
if impossible please explain.
Try this brilliant macro, all the options you need for creating springs.
Hello Greg
i can't run the micro . when i run it take an error.
hei'ya Taghi,
an old sample file SW13
may be of interest
SLDPRT file att.-
hope this helps- have a good'n kelef
Taghi,
I did create the part in a Polish version of SW.
the 3d sketch is a "intersection curve" for those two surfaces
Cheers!
thanks all
Leszek
