When I save an assembly as a new name in a folder in EPDM, it doesn't show up in the folder. I look for it via windows explorer and also by File / open within SW. This happens when, after I put in a new name for the assembly, the parts in the assembly are not checked out and windows pop for me to save them as a new filename also. I don't want to do that so I hit cancel on those dialogue boxes. The new assembly file is there because it opens if I use the File drop down and select it from recent files. I save it to my desktop then drag-and-drop it into the correct EPDM folder and I'm asked if I want to replace the existing file, so this confirms that it really is already in that folder. I do replace it and now it shows up in windows explorer and using File/Open in SW.
Anybody have a better fix?
try this setting - maybe if you don't have to cancel the other save as dialogs, the assembly will be correctly added to the vault (instead of just saved as a local file).
