I have a weldment that is drawn in position on an assembly. I am breaking groups of parts out of the assembly to create shop drawings for fabrication. How do I rotate the part in the drawing to the alignment I want?
if the model is skewed in relation to the default coordinate system you can correct it by redefining the default views in said model.
to do this, in the model,
select face of model you want to be "Front",
then holding the ctrl key,
select face you want for "Top"
now select "Normal To"
press the space bar,
select the "Update Standard Views"
then select the "Front" button
you're now ready to insert your "adjusted" model views into the drawing.
Hi Jeff,
You can use Rotate View
