is 3dvia composer 2010 compatible with solidworks 2015?
Thanks for your reply Derek.
"You may have a problem if you are using the Composer add in for Solidworks"
what did you mean by this sentence?
There is a add-in in Solidworks that is basically a quick export to smg button. Does the same thing as save as smg just saves a few mouse clicks. I don't even use it myself since I am forwards compatible now and have been warned it may be a problem. I have never experienced a problem just no need to risk it to save a few mouse clicks for me.
Rohit,
Pretty sure they are backwards compatible but not sure how far back. You may have a problem if you are using the Composer add in for Solidworks but save as smg should be fine. Might want to check with your VAR just to be sure.
Cheers,
Derek
