Greetings,
I am new here and i need help.
I have a sketch on one plane. I need to cut a curved surface whit that sketch.
I try project curve on surface and now i got projected curve on my surface but i cant cut it through.
Can anyone help me here?
I need this :
( this is made with extruded cut but i need cut to follow my edge )
btw. I have SW 2011
Josip,, I originally thought that the wrap feature would be the way to go with this. Then from you screenshot I see you are using a loft. When I tried the wrap (deboss) on this I got the same error message as you. So I used my sketch and did a split line on the surface > offset the surface (slot) 0 offset and then Cut-Thicken.
