Hello there!
I am new to Solidworks Composer and using its trial version.
I want to make BOM in it. But the Description field in BOM takes the name of the Body of the Part. The name of body is generally the last feature used for that body.
I want the Description of BOM to be the File Name of Part instead. All my components of assembly should have the File Name in the Description field of BOM.
Any comments will be helpful.
Thanks.
Bhavarth
Make sure that the description field in the part's property dialog box references its file name. You'll also want to be sure that composer's description field is pulling from the same reference.
