TBThomas Bryant15/12/2015
I would like to create a macro that is similar to Rajat Jain’s in reply #8 of this thread:
https://forum.solidworks.com/thread/41514
Only instead of using an axis, I would like to calculate the unit vector from a line drawn by the user, and put it into Excel from there.
Here’s what I’ve tried so far. It only gives a blank Excel file with the i, j, k variables. Advice would be appreciated.
Option Explicit
Sub Main()
    On Error Resume Next
    Dim swApp           As SldWorks.SldWorks
    Dim swModel         As SldWorks.ModelDoc2
    Dim swMathUtil      As SldWorks.MathUtility
    Dim swSelMgr        As SldWorks.SelectionMgr
    Dim oFeature1       As SldWorks.Feature
    Dim oMyLine         As Object
    Dim oMathVector     As SldWorks.MathVector
    Dim oUnitVector     As SldWorks.MathVector
    Dim vPt1            As Variant
    Dim vPt2            As Variant
    Dim dArr(2) As Double
    Dim i As Long
    Dim dArrUnit As Variant
    Dim xlApp As Excel.Application
    Dim xlWorkbook As Excel.Workbook
    If Not swApp Is Nothing Then
        Set swModel = swApp.ActiveDoc
        Set swMathUtil = swApp.GetMathUtility
        If Not swModel Is Nothing And Not swMathUtil Is Nothing Then
                Set oFeature1 = swSelMgr.GetSelectedObject6(1, -1)
                If Not oFeature1 Is Nothing Then
                    Set oMyLine = oFeature1.GetSpecificFeature2()
                    If Not oMyLine Is Nothing Then
dArr(0) = vPt2(0) - vPt1(0)
dArr(1) = vPt2(1) - vPt1(1)
dArr(2) = vPt2(2) - vPt2(2)
Set oMathVector = swMathUtil.CreateVector(dArr)
                        If Not oMathVector Is Nothing Then
Set oUnitVector = oMathVector.Normalise()
dArrUnit = oUnitVector.ArrayData()
MsgBox ("Line vector is " & dArr(0) & "i + " & dArr(1) & "j + " & dArr(2) & "k" & vbCrLf & "Unit vector is " & dArrUnit(0) & "i + " & dArrUnit(1) & "j + " & dArrUnit(2) & "k")
Set oUnitVector = Nothing
Set oMathVector = Nothing
Set oMyLine = Nothing
Set swSelMgr = Nothing
                Set oFeature1 = Nothing
        Set swModel = Nothing
        Set swMathUtil = Nothing
   'get the results into excel
    Set xlApp = CreateObject("Excel.Application")
    xlApp.Visible = True
    Set xlWorkbook = xlApp.Workbooks.Add
    With xlWorkbook.Worksheets(1)
    .Cells(1, 1).Value = "i"
    .Cells(1, 2).Value = "j"
    .Cells(1, 3).Value = "k"
    .Cells(i + 2, 1).Value = dArrUnit(0)
    .Cells(i + 2, 2).Value = dArrUnit(1)
    .Cells(i + 2, 3).Value = dArrUnit(2)
    End With
    Set xlWorkbook = Nothing
    Set xlApp = Nothing
