When you try to export a file using save as, the list of file types is ridiculously long. The list includes every single possible export format, so I have to sift through 35 esoteric file types to find STL or Parasolid which I use most of the time.
I would love to hide all the stuff I don't use somehow, does anyone have ideas for this? I tried googling but couldn't find anything good on this topic. Would be great if I could re-order so my favorites display first, then the others below. I would be satisfied to just figure out a registry hack and permanently remove some of them though.
Of course this is a problem with almost every program where you can save to lots of different file types whether it be on a PC or a MAC. I have the same problem with graphic design software with the myriad of image formats. I wonder if anyone else has figured out a solution to this.
My concern is when someone complains they don't have enough options, which is more often than too many.... Is it better to having to do what one has to do with AutoDesk, and select Export...?
