Structural Simulation Guidance
Question asked by Harold Black on Dec 10, 2015
Latest reply on Jan 20, 2016 by Helpdesk Emea
I am in need of guidance performing a structural simulation on a scaffold. The end result is to determine the maximum loading the scaffolding can undergo. I am having problems running the simulation.
Details:
Scaffolding is composed of two sides, each of which are created by welding together two 3" schedule 40 steel pipe to two 3" x 3" x 1/4" square tubing. The two sides of the scaffold are tied together by means of cross bars that are connected by two pins on each of the 3" schedule 40 pipes. There is a pin that runs through where the cross bars run over each other.
The components of the assembly model are created by using weldments/structural members. The scaffolding is assumed to be fixed to the ground. Loading is to be applied on the faces of the 3" schedule 40 pipe.
This is the first time I am doing a simulation on an assembly. Attached is a zip file containing the model files as well as the assembly file. Any help would be greatly appreciated.
