Option or setting to make all section views on sheet at specified scale from sheet scale?
Question asked by Dave Krum on Dec 10, 2015
Latest reply on Dec 11, 2015 by Dave Krum
Hello All,
On my drawings, I usually show my section views in a larger scale than the parent sheet scale.  I have to set each section view's scale manually from the left side dialog box that pops up for the section view.  This method works fine but I was wondering if there may be a setting that would be valid only for the given document under options/document properties that would give it a scale of say 3:1 for all newly generated section views.  I almost always break the alignment from the parent so the larger size isn't an issue for me with running out of drawing space.  See below.  The sheet scale is set at 1:7 but I am using section views at 1:1.75 scale.  I didn't see any option for changing this across the board in the document.  Thanks in advance.
