When i add three dimentions to the part, and export to a 3D PDF file.
The model is in the middle but dimentions are not when i open the pdf file.
How to to put the model and dimentions default to a suitable postion ,just like the picture No.2?
The reason i need the function is i can reduce the operation time when works read the drawings,
and they don't need to move the models to see all the dimentions from the touch panel.
***default view in exported 3D PDF .
***the view in exported 3D PDF which i moved the model.
I agree. It would be nice if the model and dimensions would center based on the graphical view. This becomes even more of an issue when you add notes to the files. Even though the notes made be hidden, the view takes their location into consideration.
I think it might be a boundary rep issue.
