Hi there,
I would like to know what is the best way to make a sort of cut loft around a corner. I tried a few times with 3d sketches and projected lines, but no succes.
The cut I want to draw is in the right bottum corner. It sweeps from the side to the front.
Does anybody know a quick way of doing this and maintain controll on the curvature?
Hi Arnaud
I'vee not opened your file, but if you have the 3d sketches in place to define the edges of the area you wish to remove, use them to create some surfaces then use those to create a split feature on the solid.
