How do i create a revolved boss given a start and stop angle.
I have a sketch drawn on the front plane.
i want to revolve this from 5 degrees to 15 degrees
solidworks apparently can only revolve based around the plane. negative numbers don't work and i cant find a way to give it that offset.
Vincent
I do not see a way. You might submit the idea for this year's Top Ten, to add a "From" setting for revolved bosses, same as for extrusions. I'd vote for it.
Dwight
