Is it possible to retake the CSWP Sample Exam? The free one that is available to get you used to the software and type of questions on the exam?
I took the sample CSWP and failed it (I ran out of time before answering any questions!!), right after taking the sample CSWA. I wanted to retake the sample CSWP then, but it was no longer an option when I reopened the testing client. I deleted the testing client files and the sample CSWP was back so I retook it then and passed.
Yet this was lacking in reality because I knew the answers and, though I took the time to redo the models, I knew what to do so I was able to finish it and pass.
Now I want to retake the sample CSWP again since I will actually be taking the CSWP in January. Except it is not an option and nothing I do seem to get it back. Is it because I have passed? Is it possible to retake it anyway? Is there some workaround out there?
You can retake the sample exam up until you pass it. You can check your Exam Results through the SOLIDWORKS Certification Center (http://solidworks.virtualtester.com). After logging into your account, select 'Exam Results' to review your sessions. The system is showing that you passed the CSWP sample exam. If you have additional questions, you can contact the certification team directly by emailing us at certification@solidworks.com
