I don't believe you can. The origin will maintain it's position on the drawing view, so if a body moves relative to the origin in the model it will move in the drawing view.
OK. Thanks. Maybe I should explain more. I don't mind the parts moving a little in the drawing, but the dimensions don't seem to move with the part. Is that normal?
If you want the assembly to move and have a drawing made from it look at making a configuration in the assembly that has all the components defined so they can not move and another configuration that can have a limit mate or freedom to move this way the drawing will not be affected.
