Hi, there,
I am new to simulation. watched some youtube, they talked about the load to analys the stress at certain area, I would like to konw how to do this,
I have a part need clipped on another part when assembly, also I know when assembly it, the mouth need be opened about 0.3mm, how to simulate the situation to see if the part break or not, let's say the material is PEEK.
thank you in advance!
Eric
Load your tube with internal pressure (or force) to expend tube ID at .3 mm to fit assembly requirement. (This is the way to simulate the tube in assembly mode). Run the Simulation Study and analyze results. Check if:
If for both questions the answer is “YES”, you are OK and part will be not destroyed during assembly.
