It was necessary to make changes to the sheet format in my drawing template that will be reflected in all of my drawings going forward. However, I'm often asked to send out old drawings for fabrication. Is there an easy way to update my old drawings without manually making the changes to each one? Can I import the new template into an old drawing or something that would have the same effect?
With the drawing open, right click in the graphics area and select properties. From there you can change the sheet format.
