Can someone please point a semi green user to where to info on properly setting up cut lists? We have SW2015 Professional.
I am trying to set up drawings so that either the BOM or Cut list will give a total of qty of inches of, say, 2" sq. tubing or 1" dia steel or U-Channel is contained in the assembly, which consists or primarily weldments and hardware parts.
Any help will be appreciated, greatly. Thanks!
Welcome to the forum. There is a cut list property "TOTAL LENGTH". It sounds like that will do what you need. You can reference it with a note...
...or in a cut list column.
