I am working on a problem that requires a big number of spring connectors (more than 75) connected to a great number of faces. The result is a very slow interface each time I need to edit the definition of a connector, because SW keep refreshing the list of selected faces. I need to change the values of stiffness (in N/m/m²) and preload force (in N/m²) for all, but hopefuly, all share the same values, only difference is the set of faces to which they apply.
Is there a way to edit these values without opening each spring connector's property manager ?
I wanted to link each to a parameter, but SW 2015 won't link two parameters with different units to the same connector ? How this is possible ?
In the parameter dialog box, my fist parameter is correctly linked to Normal stiffness.
When I try to link the second parameter to preload force, a link to Normal stiffness is already created and I can't remove it ? Thus it is not possible to link the second parameter to preload.
Please help !
Thank you very much.
Ok I found a solution : use a macro.
Not very effective but it works.
Next problem is how to add a load and restraints with the API by retrieving the selection sets !
