I create a screw-on cap for a coffee mug and release it as Revision A.
If the cap leaks, I change the depth of the groove for the seal. After the depth change, the part becomes Revision B.
Now, Revision A and B will both fit the mug and Revision B is backward compatible to Revision A.
If I change the thread to a finer pitch, creating more pressure on the seal, does the part still become Revision B, or would the part require a new part number?
Now, Revision B will no longer fit the same mug as Revision A, so Revision B is not backward compatible to Revision A.
Must all revisions be backward compatible with their previous revision?
Thank you,
Carl
Most follow the three F's: Form, Fit, Function. If any of the three change such that the new version can not be used in place of the previous version, then a new part has been created necessitating a new part number.
