When I trim surfaces using mutual option then a check box(create solid) appears, also it is deactivated by default. I am not sure about why this provided. Anyone can provide suggestion on this?
Hi Jitendra Gahalot create solid appears when you are using knit surface or fill surface. when ever you want the surface to be came solid body by using fill or knit surface create solid will highlight but it works only when all the surface are merged together and creates an closed volume. create sold will only highlight when ever you check the merge result. i have attached an example to show how it works
