Hi I'm Ulaş Kaya
i have kinda Bad Problem About My SolidWork.
when we taking a section any model type (as a 3d Solid Item) The model Middle Side or inside never been stuffed solid always look like thisthis Selected places must be solid right but i make so many solutions about to fix it as in program setting/options or my NVİDİA GeForce GT 525M 4GB Screen Card Basic And High Level Setting even try Get Reser Both Of them setting but this shit ever work,
but i wonder about nearly 1 year abo i work on my computer with 3 Visual Studio And 2 3ds Max By Autodesk my computer cooling system has givin a report to some about issues and i removed the colling system from my computer (this is not a cpu cooling system) (this is general cooling for every places build for myself) just 2 min later my computer has shot down after when i open all the program before the shot down vs working good , 3ds max working good there no problem about the video card but but i doubt about this problem show your face for this is anybody say something how to fix that issues or tech problem
Hi Ulas,
Firstly you did open the discussion in the wrong place by mistake i guess. Composer is totally different software from SOLIDWORKS.
If you suspect of any lack of graphic card requirement is the main reason of this behaviour you can easily test it by opening SOLIDWORKS in open gl mode.
Besides I see your graphics card (NVİDİA GeForce) is not supported by SOLIDWORKS.See the Certified Graphics Card Drivers | SOLIDWORKS
It means that performance of your graphic driver in SOLIDWORKS is unpredictable. It's hard to make a comment for a permanent workaround if it Works good in open gl mode continue to use that or change your graphic card with a certified one.
Cheers. Yigit
