Macro to Change Properties of Part in Drawing View
Question asked by Tony Thompson on Nov 27, 2015
Latest reply on Nov 27, 2015 by Amen Allah Jlili
Hello
We are using the Custom Property Tab Builder to create templates for adding custom properties to our part and assembly files that populate all of the title block and BOM information in our drawings that is working very well and the only custom property we have in the drawing is the Revision property so it will work with the Revision Table when entered. There are two things I would like to accomplish with a Macro.
1st we have a custom property in the part and assembly files called Shop Order that will change if the part is reordered at a later time and I would like to be able to open the drawing only and change the Shop Order custom property in the part or assembly file that is in the drawing view (which is the same name as the drawing) that we have a link in the title block to this property.
2nd I would like to have a Revision custom property in the part file that the macro would fill in based on the Revision custom property in the drawing.
Also on a slightly different note it would be great to somehow keep a list of all of the Shop Order numbers used for the parts but is just a wish list if this would be possible to do.
We are using SolidWorks 2015 sp4 and we do not have an EPDM but it is on our wish list so we are trying to setup our system so that our part, assembly and drawings already have the custom properties in them to be able to populate the EPDM if or when we move to it.
Tony
