13 Replies Latest reply on Nov 28, 2015 10:46 AM by Franz Dahinden
    get current sheet as PDF
    Franz Dahinden
      someone know how to change it. I like to get only current sheet. when use the macro. Thanks a lot.
      Dim swApp           As SldWorks.SldWorks
      Dim swModel         As SldWorks.ModelDoc2
      Dim swDrawModel     As SldWorks.ModelDoc2
      Dim swDraw          As SldWorks.DrawingDoc
      Dim swView          As SldWorks.View
      Dim nErrors         As Long
      Dim nWarnings       As Long
      Dim Revision As String
      Set swDrawModel = swApp.ActiveDoc
      If swDrawModel Is Nothing Then
              MsgBox "There is no active drawing document"
              Exit Sub
      If swDrawModel.GetType <> swDocDRAWING Then
              MsgBox "Open a drawing first and then TRY again!"
              Exit Sub
      Set swDraw = swDrawModel
      Set swView = swDraw.GetFirstView
      Set swView = swView.GetNextView
      Set swModel = swView.ReferencedDocument
      If swModel.GetPathName = "" Then
              MsgBox "Insert a View first and then TRY again!"
              Exit Sub
      Index = swModel.GetCustomInfoValue("", "Index") ' Change Revision property name here if different
      If Index = "" Then
              Index = ""
      Else
          Index = "_(" & Index & ")"
      swDraw.SaveAs3 Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, ".") - 1) & Prop & Index & ".PDF", 0, 0
        • Re: get current sheet as PDF
          Robert Kite
          Hi Franz
          You'll need to change:
          to be...
          'Get PDF export Data
          Dim swExportPDFData as SldWorks.ExportPdfData
          Set swExportPDFData = swApp.GetExportFileData(1)
          'Set the PDF to only include current sheet
          Dim boolstatus As Boolean
          boolstatus = swExportPDFData.SetSheets(swExportDataSheetsToExport_e.swExportData_ExportCurrentSheet, Nothing)
          'Save out the PDF
          boolstatus = swDrawModel.Extension.SaveAs(swDraw.GetPathName, 0, 1, swExportPDFData, 0, 0)
          Hope that helps!
          Rob
              Franz Dahinden
              I need also the Index from part, is lost
                  Amen Allah Jlili
                  Cheers,
                  Dim nErrors        As Long
                          Exit Sub
                          Exit Sub
                          Exit Sub
                  If Index = "" Then
                          Index = ""
                  Else
                  'Save out the PDF
                  boolstatus = swDrawModel.Extension.SaveAs(Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, ".") - 1) & Prop & Index & ".PDF", 0, 1, swExportPDFData, 0, 0)
                    Robert Kite
                    You're using an obsolete call to obtain the custom property currently, but they generally still work (I've not tested in this case). My solution below is a bit lazy as I use Get (ICustomPropertyManager) rather than the superseding Get5, simply because it's less work in this case.
                    Replace:
                    If Index = "" Then
                            Index = ""
                    Else
                    With...
                    'Get the general custom property manager for the model
                    Dim cpm As CustomPropertyManager
                    Set cpm = swModel.Extension.CustomPropertyManager("")
                    'Get the custom property called Index
                    Dim index As String
                    index = cpm.Get("Index")
                    'Format the index string, assuming something was returned
                    If index <> "" Then
                         index = "_(" & index & ")"
                        Franz Dahinden
                        Sorry my question, is it possible to add the sheet Name?
                            Amen Allah Jlili
                            Sure man, anything for my SW peep.
                            Just make sure that the sheet name does not contain any file-naming illegal character.
                            Dim nErrors        As Long
                                    Exit Sub
                                    Exit Sub
                                    Exit Sub
                            If Index = "" Then
                                    Index = ""
                            Else
                            Dim swExportPDFData As SldWorks.ExportPdfData
                            ' Get current sheet name
                            Dim swsheet As sheet
                            Set swsheet = swDraw.GetCurrentSheet
                            'Save out the PDF
                            boolstatus = swDrawModel.Extension.SaveAs(Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, ".") - 1) & Prop & Index & swsheet.GetName & ".PDF", 0, 1, swExportPDFData, 0, 0)
