EDrawings Viewer 2015se won't open certain .slddrw files after installing EPDM.
Question asked by Armand Brown on Nov 25, 2015
The problem that I'm having is that EDrawings Viewer 2015se works fine and will open all of our .slddrw files without issue. As soon as Enterprise PDM is installed certain .slddrw files won't open and I get "EModelViewer Module has stopped working". I've tried various fixes and nothing helps.
The systems that I'm using are Windows 7 32bit with Intel graphics
The two recorded events I'm getting are:
Faulting application name: EModelViewer.exe, version: 14.6.0.20, time stamp: 0x5463b740
Faulting module name: mfc110u.dll, version: 11.0.60610.1, time stamp: 0x51b50f28
Exception code: 0xc0000005
Fault offset: 0x000096df
Faulting process id: 0x16b4
Faulting application start time: 0x01d127a395f453e3
Faulting application path: C:\Program Files\Common Files\eDrawings2015SE\EModelViewer.exe
Faulting module path: C:\Windows\system32\mfc110u.dll
Application: EModelViewer.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: exception code c0000005, exception address 631396DF
Any help is appreciated.
