1 Reply Latest reply on Nov 26, 2015 4:08 PM by Peter Brinkhuis
    Integrate opening Equation Manager in Macro
    Michiel Koppelman
      Hope somebody can help me with this problem:
      I have a Macro running that I found online to update te design tables of multiple parts in an assembly. Which works great to drive an assembly from an external Excel file.
      In a few of the sub-assemblies there are also a few Equations driven from the design tables, which should ideally be updated when te design tables are updated.
      I noticed just opening the Equation Manager by hand does the job, but I thought a smarter and quicker way to do it would be to incorporate the opening and closing of the Equation Manager (i.e. updating) in the running Macro just after the opening and closing of the Design Table in that particular part. I just don't know how..
      Any ideas? Thanks a lot in advance!
      This is the Macro code:
      Sub DesTblUpdate()
      Dim swDoc As SldWorks.ModelDoc2
      Dim swDocXt As SldWorks.ModelDocExtension
      Dim DesTbl As SldWorks.DesignTable
      Dim swAllDocs As EnumDocuments2
      Dim FirstDoc As SldWorks.ModelDoc2
      Dim dummy As Boolean
      Dim NumDocsReturned As Long
      Dim DocCount As Long
      Dim DesTblCount As Long
      Dim i As Long
      Dim DoTheUpdate As Long
      Dim sMsg As String
      Dim bDocWasVisible As Boolean
      Set swAllDocs = swApp.EnumDocuments2
      Set FirstDoc = swApp.ActiveDoc
      DocCount = 0
      DesTblCount = 0
      swAllDocs.Next 1, swDoc, NumDocsReturned
      While NumDocsReturned <> 0
          Set swDocXt = swDoc.Extension
          If swDocXt.HasDesignTable Then
              DesTblCount = DesTblCount + 1
          DocCount = DocCount + 1
      Wend
      sMsg = DocCount & " Documents, " & DesTblCount & " of which had design tables"
      sMsg = sMsg & vbCrLf & vbCrLf & "Do you want to update all these tables?"
      DoTheUpdate = MsgBox(sMsg, vbYesNo, "Update Design Tables?")
      If DoTheUpdate = vbNo Then
          Exit Sub
      DocCount = 0
      DesTblCount = 0
      swAllDocs.Reset
              bDocWasVisible = swDoc.Visible
              swApp.ActivateDoc swDoc.GetPathName
              Set DesTbl = swDoc.GetDesignTable
              dummy = DesTbl.Attach
              dummy = DesTbl.UpdateTable(swDesignTableUpdateOptions_e.swUpdateDesignTableAll, True)
              DesTbl.Detach
              swDoc.Visible = bDocWasVisible
      Wend
      swApp.ActivateDoc FirstDoc.GetPathName
