I created a helix for a path, and cut with a section. It almost looks like a drill bit. Now I want to mill these slots on a 4 axis mill.
I can use a ball nose cutter to mill the slot. It will cut a full radius at the end. Then I intend to use a chamfer tool finish the bevel on both sides.
The bevel tool has no radius path at the end.
How can finish this part to create a full radius for the slot and the chamfer, at the end of the helix.
Any modeling ideas?
Solid Sweep 2012 SOLIDWORKS Help - Sweep PropertyManager
