Is there a easy way to select "hidden" items in a drawing. For example, in this example below some text is overlapping another block of text. When I try to select the smaller text, it keeps selecting the larger, multiline text. Is there a way perhaps to cycle through selections like in Autocad (cntl clicking will cycle through close/overlapping objects)? Surely this must be a common procedure. Thanks.
You can try right-clicking and choosing "Select Other". If that doesn't work, move the larger one out of the way. Then move the smaller one to where you want and move the large one back.
