3 Replies Latest reply on Nov 25, 2015 1:59 AM by Franz Dahinden
    Singles PDF (current) with sheet name and Index macro
    Franz Dahinden
      I would like to change the macro. The name of the current sheet and the index from part or assy  (inkl. already) should be stored in file of PDF.
      For example-->  Massbild-FileNr.-sheetname-A. --> Massbild-455266-coverplate-A.
      It should save only the current sheet.
      Anyone can help me for add the necessary Information.
        • Re: Singles PDF (current) with sheet name and Index macro
          Dmitry Zamoshnikov
          look up:
          http://help.solidworks.com/2012/English/api/sldworksapi/Save_File_As_PDF_Example_VB.htm
          You'll have to parse the file name.
          filepath = ModelDoc2.GetPathName
          /* search for the final occurance of the '/' character in the file path.
             that will get you the index
             do newFilepath = Strings.Right(filepath, Strings.Len(filepath)-index)) to parse out the file name
             newFilepath = Strings.Left(newFilePath, Strings.Len(newFilePath)-7 to get rid of the extension
             Now you can start to add things to the file path
              Franz Dahinden
              Hello Dmitry Zamoshnikov,
              thanks für help.  I should change my macro PDF-Revision or the macro from SolidWorks?
              Perhaps is to difficult for me, if you not tell me wich line i have to change.
              ' Preconditions: The specified drawing document exists.
              '                NOTE: The  drawing document is installed when
              '                      you  install SolidWorks.
              ' Postconditions: The specified sheet is exported to a  PDF file.
              Option Explicit
                  Dim  swApp               As  SldWorks.SldWorks
                  Dim  swModel             As  SldWorks.ModelDoc2
                  Dim  swModelDocExt       As  SldWorks.ModelDocExtension
                  Dim  swExportPDFData     As  SldWorks.ExportPdfData
                  Dim  boolstatus          As  Boolean
                  Dim  filename            As  String
                  Dim  lErrors             As  Long
                  Dim  lWarnings           As  Long
                  Dim  strSheetName(4)     As  String
                  Dim  varSheetName        As  Variant
                  '  Path to which to save PDF file of drawing
                  filename  = "C:\foodprocessor.PDF"
                  Set  swApp = Application.SldWorks
                  swApp.Visible  = True
                  '  Open specified drawing
                  Set  swModel = swApp.OpenDoc6("c:\Program  Files\SolidWorks\samples\tutorial\advdrawings\foodprocessor.slddrw",  swDocDRAWING, swOpenDocOptions_Silent, "", lErrors, lWarnings)
                  Set  swModelDocExt = swModel.Extension
                  Set  swExportPDFData = swApp.GetExportFileData(1)
                  '  Names of the sheets
                  strSheetName(0)  = "Sheet1"
                  '  strSheetName(1) = "Sheet2"
                  '  strSheetName(2) = "Sheet3"
                  '  strSheetName(3) = "Sheet4"
                  varSheetName  = strSheetName
                  If  swExportPDFData Is Nothing Then MsgBox "Nothing"
                  boolstatus  = swExportPDFData.SetSheets(swExportData_ExportSpecifiedSheets,  varSheetName)
              boolstatus = swModelDocExt.SaveAs(filename,  0, 0, swExportPDFData, lErrors, lWarnings)
