No one else has this question
You can simply use the cut extrude and then offset from surface option in that to cut to some depth maintaining the same surface OR even Wrap feature with deboss option.
Using this technique, you can get a nice result (how to project icosahedron on a sphere? ) It's a way to wrap it, because I don't think you can wrap on a surface with complex curvature.
Try Split-Line.
