Save PDF -> DrawingDoc_FileSavePostNotify Loop problem
roberto gennari Nov 24, 2015 1:31 AMHello to all,
I am creating an addin where every time you save a drawing'm going to create the pdf file, so it is always updated.
This is my problem:
I entered my code saving pdf event
DrawingDoc_FileSavePostNotify () As Integer
but the event is unleashed every even when the PDF is saved, creating a loop.
Below I report my code contained in the event DrawingDoc_FileSavePostNotify () As Integer, I do not know if you can solve with a flag or if it moved to another event.
Thank you all
Function DrawingDoc_FileSavePostNotify() As Integer
Dim PathFile As String = System.IO.Path.GetDirectoryName(iDrawing.GetPathName)
Dim Myfile As String = PathFile & "\" & System.IO.Path.GetFileNameWithoutExtension(iDrawing.GetPathName)' Senza estensione
Dim swExportPDFData As ExportPdfData
Dim swDrawDoc As DrawingDoc
Dim MyModel As ModelDoc2
Dim swModExt As ModelDocExtension
Dim boolstatus As Boolean
Dim filename As String
Dim errors As Integer
Dim warnings As Integer
Dim objs() As Object
Dim obj As Object
MyModel = iSwApp.ActiveDoc
swModExt = MyModel.Extension
If mTaskpaneHost_1.cb_Salva_Tavola.Checked = True And mTaskpaneHost_1.cb_Pdf.Checked = True Then
swExportPDFData = iSwApp.GetExportFileData(swExportDataFileType_e.swExportPdfData)
' Get the names of the drawing sheets in the drawing
' to get the size of the array of drawing sheets
swDrawDoc = MyModel
obj = swDrawDoc.GetSheetNames
Dim count As Integer
count = UBound(obj)
ReDim objs(count)
Dim arrObjIn(count) As DispatchWrapper
Dim i As Integer
'Activate each drawing sheet, except the last drawing sheet, for
'demonstration purposes only and add each sheet to an array
' of drawing sheets
For i = 0 To count - 1
boolstatus = swDrawDoc.ActivateSheet(obj(i))
Dim swSheet As Sheet
swSheet = swDrawDoc.GetCurrentSheet
objs(i) = swSheet
arrObjIn(i) = New DispatchWrapper(objs(i))
Next i
' Save the drawings sheets to a PDF file
boolstatus = swExportPDFData.SetSheets(swExportDataSheetsToExport_e.swExportData_ExportSpecifiedSheets,(arrObjIn)).
''''''HERE START THE LOOP'''''''''
swExportPDFData.ViewPdfAfterSaving= False
Debug.Print(swExportPDFData.ViewPdfAfterSaving)
boolstatus = swModExt.SaveAs(Myfile & ".pdf", swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Silent,swExportPDFData,errors,warnings)
If boolstatus = True Then
MyNode = mTaskpaneHost_1.Tv.Nodes.Find("Oggi",True)
MyNode(0).Nodes.Add("", Myfile & ".pdf", 1)
Else
MyNode(0).Nodes.Add("", Myfile & ".pdf", 4)
End Function
