Why become like this....have any solution can solve this problem...
Do you've something selected and at same time you're rotating the view? If yes then release the mouse button and dimension should display correctly.
But i just put the dimension and then cannot select again ...normally if put dimension want to change ,double click can change right...but this cannot...
That is applicable for sketches OR some features dimensions. The one you're adding are driven dimensions.
