I have been using lofted boss/base for circular faces but was wandering if this feature can be used for other faces as well ?
Please explain how this feature works and on what faces? Thanks
You can Loft between almost any shape of face or sketch. The screenshot below is of a loft between a square and a circle.
I've found it helps if the loft profiles have the same number of sketch segments or edges, but it isn't necessary. That only makes it easier to control the outcome.
