17 Replies Latest reply on Oct 3, 2018 12:46 PM by Wayne Schafer
    Macro to open drawing from Part Model
    Alvin Heng
      Hey guys, I have been using this macro to open drawings of components in an assembly by first opening the component model manually, then run the macro to open the drawing. This has worked pretty well, however I have been opening a lot of drawings and it slows down my computer significantly. I have tried to modify the code to open the drawing in quick view mode but I just couldnt get it to work.
      Dim swApp As Object
      Dim sFileName As String
      Dim Part As Object
      Set Part = swApp.ActiveDoc
      Set fso = CreateObject("Scripting.FileSystemObject")
      sFileName = Left$(Part.GetPathName, (Len(Part.GetPathName) - 6)) & "SLDDRW"
      If fso.FileExists(sFileName) Then
          Set Part = swApp.OpenDoc(sFileName, swDocDRAWING)
          Else: MsgBox ("Drawing does not exist")
      On a separate note, if there is a way to open any component drawing directly from the assembly drawing (without opening the component model), that will be awesome! However I'll also need the macro to open the drawing from part model. Thanks a lot guys!!! Its much appreciated.
