Hello, I am having a lot of difficulty with this script. The intention is to loop through all of the components in an assembly (which contains sub assemblies) and isolate all of the components that do not have material properties assigned to them (for weight estimation purposes).
I am getting an Error 91 at 'If swModel.MaterialIdName <> "" Then' for some components (but not all). Using the debugger, I can see that the suppression state of the component is not changed from lightweight to resolved by the .SetSuppression2 method. Any idea why this would be?
The code is as follows. Thank you!
Dim swModel As ModelDoc2
Dim vComps As Variant
Dim swcomp As SldWorks.Component2
Dim i As Integer
Dim suppressionState As Long
Set swModel = swApp.ActiveDoc
If swModel.GetType = swDocASSEMBLY Then
Set swAssy = swModel
vComps = swAssy.GetComponents(False)
For i = 0 To UBound(vComps)
Debug.Print i & " / " & UBound(vComps)
Set swcomp = vComps(i)
suppressionState = swcomp.GetSuppression
If suppressionState <> swComponentSuppressed Then
If suppressionState <> swComponentFullyResolved Then
swcomp.SetSuppression2 (swComponentFullyResolved)
Set swModel = swcomp.GetModelDoc2
swcomp.Visible = False
Next i
swModel.EditRebuild3
You're not calling the enum properly. Replace swComponentFullyResolved with swComponentSuppressionState_e.swComponentFullyResolved
or just replaceswComponentFullyResolved its value 2.
If you want to use swComponentSuppressionState_e make sure that solidworks const library tlb is referenced. VBA automatically references it for you when you're create a new macro.
