1. If you have different drawings sheets added (for different part detailing), you can export all sheets as a different dxf. You need to set option "export all sheets as separate files" while saving dxf.
2. I f you have view for the parts, you can directly save that view from drawings property pane in the bottom. Click the save view as, select the position of the manipulator and save it as dxf.
Hi Ashok,
