I must make a hole in the tube i'v got here:
(screen1 and screen2 )
The hole must have a 2mm smaller size as the small tube,
(screen3)
Can somebody tell me how to do that?
whatever i try... it don't do what i want it does.
would be great if someone can help me!
It sounds like what you want to do is:
create a new sketch on the surface of the flat end of the small tube
offset entity and select the inside edge of the small tube - set offset at 2mm
extrude cut up to next in order to cut through larger diameter tube.
