Sw 2013 Cut list marco problem
Question asked by Pieter Tessel on Nov 17, 2015
Latest reply on Nov 17, 2015 by Viktor Bovzdarenko
The problem is that my macro searches for fist feature called "Cut-list-item1", but sometimes if i open a older part the cut list is called "Cut-list-item2" or even "Cut-list-item6".
i tried to filter the name so if it contains "Cut-list-Item''  it will grab that one, but i can figure it out.
Thanks in advance,
Pieter Tessel.
Solidworks 2013 Cut list macro:
    Dim swFeat As SldWorks.Feature
    Dim swCustPropMgr As SldWorks.CustomPropertyManager
    Dim retval As String
    Set swModel = swApp.ActiveDoc
    Set swFeat = swModel.FirstFeature
    retval = swModel.AddCustomInfo3("", "Stocksize", swCustomInfoText, "")
    Dim strValue As String
    Do While Not swFeat Is Nothing
        If swFeat.Name = "Cut-List-Item1" Then
           Set swCustPropMgr = swFeat.CustomPropertyManager
            swCustPropMgr.Get4 "Description", False, Empty, strValue
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Empty)
            swCustPropMgr.Set "Stocksize", strValue
          Exit Do
       Set swFeat = swFeat.GetNextFeature
       Loop
