Please how to
save a multi-sheet drawing of Solid Works to a single sheet DXF or DWG or sheet
drawing of DXF or DWG particular case when the multi-sheet drawing of Solid
Works have different views scale on different sheets and how the sheet from DXF
or DWG file can be match with sheet format from Solid Works sheet format for
printing reason? For example format 11” x 17”, thank you.
From SolidWorks to dxf or dwg..
If you have a multiple sheet file then you can only save it as a multiple sheet dxf or dwg file. When you "Save As" there is a Options button where you can change a few settings
