Hi everyone,
Not sure if this is even possible but thought I would ask before ruling it out!
Situation:
I'm trying to make configurable cylinders vs stroke.
The Main configuration would be Stroke length and derived configurations would be
"Free", "In" and "Out" which would control the piston position.
(Don't really want to use flexible assemblies.)
Question:
I would like to select the main configuration when I insert a cylinder into an assembly
without the derived configurations showing.
Once the cylinder is in the assembly, all main configurations would be hidden and only the derived configurations
would be shown :
The main reason why we would like to do this is to prevent someone from accidentally changing stroke and ordering the wrong one.
Like I said, really not sure if this is even possible...
Thanks for you time,
Kevin Chisholm
Just thought of something else I could do but probably isn't possible either!!
Is it possible to have a body move freely in a part?
I'm thinking the only way would be with equations in a Design Table... But not even sure if that is possible.
It is possible to limit the dimension of 21.25mm in my example so it can go between 21.25mm to 26.25mm?
Thanks for any help!
Kevin Chisholm
