I seem to be having a problem with adding corner edge relief to bent edges in the sheet metal Module. If I try flattening the part and making cuts the cuts disappear. What am I doing wrong??
Take a look at this Ryan. The cuts should be put in between an "Unfold" and a "Fold".. I did this on one side of the part but you will get the idea. Also no thought was put into dimensioning the cuts. I would need the part to do that
