Hello !
I have modified a macro in SW 2015 SP4, it was not completed but it worked for me. I saved it and now when I try to edit, SW crash. I can edit other macro without any issues.There is someone here who can try to open it in another version.If it works, sending me a text version of the code would be really appreciated!
I can open your macro without a problem
Dim cwApp As CAMWORKSLib.cwApp
Dim cwDoc As CAMWORKSLib.cwDoc
Dim PostFileName As String
Dim strSetupName As String
Dim docTitle As String
Dim nNumSetups As Integer
Dim nErrors As Long
Dim nWarnings As Long
Dim blTlpGen As Boolean
'Get Solidworks App
'Get Active Model Doc
Set swModel = swApp.ActiveDoc
Set cwApp = New CAMWORKSLib.cwApp
Set cwDoc = cwApp.IGetActiveDoc
Set PartDoc = cwDoc
Set CWMachine = PartDoc.IGetMachine
'Document Title
Set swPart = swApp.ActiveDoc
docTitle = swModel.GetTitle
If InStr(docTitle, " ") > 0 Then
docTitle = Replace(docTitle, " ", "_")
Set cwMach = cwDoc.IGetMachine
'Renumber all setups if not named
Set setups = cwMach.IGetEnumOpSetups
nNumSetups = setups.Count
For i = 0 To setups.Count - 1
Set setup = setups.Item(i)
strSetupName = setup.GetName
Dim lngSetupNameLength As Integer
lngSetupNameLength = Len(strSetupName)
If lngSetupNameLength > 5 Then setup.SetName (i + 1)
Next i
'Set Letter
Dim Letter As String
If nNumSetups > 1 Then
If Not IsNumeric(Right(docTitle, 1)) Then
Letter = "1"
Else
Letter = "A"
Else
Letter = ""
'Post Process
'MW_SELNSET_TYPE_MILL_OPSETUPS = 7
'Method to get all selected operations
Dim z%
'Dim setups As CAMWORKSLib.CWDispatchCollection
Dim selectionMgr As CAMWORKSLib.CWSelectionMgr
Dim nSelectionType, nBrowserType As Long
Set selectionMgr = cwDoc.IGetSelectionMgr
nSelectionType = 7
nBrowserType = 1
Set setups = selectionMgr.GetSelectionsOfType(7, 1) 'get selected setups from "operation tab"
If setups Is Nothing Then
MsgBox "No Setup selected"
GoTo test
'nseloperations = setups.Count
MsgBox (setups.Count) & " Setup selected"
For z = 0 To setups.Count - 1
'Set lstSelSetups(z) = setups.Item(z)
MsgBox "This is Setup " & z + 1
Next z
GoTo test
For j = 0 To setups.Count - 1
Set setup = setups.Item(j)
Set operations = setup.IGetEnumOperations
If setup.GetSuppress = True Or operations.Count = 0 Then GoTo postskip
For k = 0 To operations.Count - 1
Set operation = operations.Item(k)
If operation.GetIsToolpathGenerated = True Then blTlpGen = True
Next k
If blTlpGen = True Then setup.GenerateToolpath
If blTlpGen = False And cwMach.MachType <> CW_MACHINE_TYPE_TURN Then GoTo postskip
blTlpGen = False
If cwMach.Name = "Takumi MV15" Then
Call CWMachine.SetController("FANUC18I.ctl", "C:\CAMWorksData\Posts\FANUC18I.ctl")
docpath = "\\PRBDC01\DESSINS\CNC\NETWORK\takumiv15" & "\"
PostFileName = docpath & docTitle & Letter & ".N"
If cwMach.Name = "Takumi VC0851" Then
docpath = "\\PRBDC01\DESSINS\CNC\NETWORK\takumivc0851" & "\"
If cwMach.Name = "Maximart Mill" Then
Call CWMachine.SetController("ANILAM.ctl", "C:\CAMWorksData\Posts\ANILAM.ctl")
docpath = "\\Nas-prb\maxi" & "\"
Dim lngNumberOfCharacters As Long
lngNumberOfCharacters = Len(docTitle)
If lngNumberOfCharacters = 7 Then docTitle = Right(docTitle, 5)
If lngNumberOfCharacters = 8 Then docTitle = Right(docTitle, 6)
If lngNumberOfCharacters = 9 Then docTitle = Right(docTitle, 7)
PostFileName = docpath & docTitle & Letter & ".M"
If cwMach.Name = "Ecoca MT-208" Then
Call CWMachine.SetController("FANUC0IT.ctl", "C:\CAMWorksData\Posts\FANUC0IT.ctl")
docpath = "\\PRBDC01\DESSINS\CNC\NETWORK\Ecoca" & "\"
PostFileName = docpath & docTitle & Letter & ".L"
setup.PostProcess PostFileName
Letter = Chr(Asc(Letter) + 1)
postskip:
Next j
swModel.Save3 1, nErrors, nWarnings
Set cwApp = Nothing
Set swApp = Nothing
test:
